What shocks will work with the fabtech coil over 3.5" lift? Where can i purchase these shocks seperate from the lift? will any rancho shocks work?
coil overs are the a combination of both shock and spring.
$850 for these notice thw shock in the middle. It is the same for a strut.
would you suggest the king setup over fabtech?
Hell yea with out a doubt
http://www.protrux.net/products/susp...lover_6lug.htm
It is what I am getting for my front eventually......
one more question....what shocks for the rear? i dont need anything extreme, just something that works.Originally Posted by Hyperlite
Hell yea with out a doubthttp://www.protrux.net/products/susp...lover_6lug.htm
Old Man Emu coils and springs
I got mine from www.4x4connection.com
Too bad you live that far away. Protrux is a great place with great people. I got my timing chain done there. Great prices, too.Originally Posted by Hyperlite
I'm also trying to get a job there. Gonna check back with them sometime this week.
You would go with these over the S-A-Ws? I read somewhere that they were so much more expensive and were so much softer..and were not as good with a aftermarket bumper and winch... I wish I knew where that article was... I do not know, I am just going off of what I read... Originally Posted by Hyperlite
I will say this for the KINGS...they sure are puurty
What are the S-A-W's?Originally Posted by Herkengineer
Quote:
Sway a Way RaceRunner CoiloverOriginally Posted by kenandjenn
Sway a Way RaceRunner Coilover are a very popular brand that many people have in the Yotatech community.
As for the Kings being soft, you can adjust the height or you can add or remove the gas to make them stiff or soft
Also the Kings are 4" adjustable where SAWs and Fabtech are a 3" adjustable
Actually I dont think they would recomend adding or removing the pressure out of the shock, they are designed to run at a certain pressure. You can adjust the valving of the shock or get heavier coils for them.Originally Posted by Hyperlite
Sway a Way RaceRunner Coilover are a very popular brand that many people have in the Yotatech community. As for the Kings being soft, you can adjust the height or you can add or remove the gas to make them stiff or soft
