Trouble shooting help (99-00 LImited 4runner t-case)
Subscribe
Apr 7, 2010 | 08:05 PM
I need someone to try some stuff for me. I need you to turn the car on, shift your t-case into Neutral, confirm its in Neutral, then turn off car and remove key. Now try to shift T case out of neutral. Can you? what about the rest of the settings
I'd do it myself but my T-case is in my living room.
I cant get my case to shft after taking apaprt/putting together my t-case. Cant figure out if its because the electric isnt hooked up, or i bumbled it up.
Thanks!!!
Reply 0
Apr 8, 2010 | 08:09 AM
sameless bump.
Reply 0
Apr 8, 2010 | 08:51 AM
i can check when i go home. I know i had to turn the acc on and then i could put it in neutral after placing my foot on the brake. But i can't remember if i had to put it back into park the same way.
I was lubing the driveshaft and needed it to rotate.
Reply 0
Apr 8, 2010 | 10:29 AM
Transfer case not transmission. Iddk if that's what you were talking about.
Reply 0
Apr 8, 2010 | 10:43 AM
yeah transmission
Reply 0
Apr 8, 2010 | 02:51 PM
Someone?
Reply 0
Apr 8, 2010 | 02:59 PM
would but I have a manual!!! and a bump to you...
Reply 0
Apr 8, 2010 | 04:21 PM
still around for the answer. had to put my slippers on for this
Ok. Car running put t-case into N and red light came on saying so and it rolled back.
Turned off- removed key. Would not shift from N.... NOW. After setting everything back to normal I tried 1 more time.
Started enging shifted into 4H and put in gear to get the 4X (green) light on. Then into N and confirmed, turned off and removed key. This time I was able to shift throughout all the gears 4L-n-4H-2 then back the other way to 4L and N. Was just a little tricky or sticky getting from N to 4H slot.
Hope this works out.
Reply 0
Apr 8, 2010 | 05:14 PM
Quote: still around for the answer. had to put my slippers on for this
Hmmmm thanks!!! +karma. Looks like I'll bring the case out to the car and put it in and test instead of pulling it apart again. It should work.. I hope. I'll keep you updated tomorrow
Reply 0
