Tacoma 2002 3.4 - Startup (fuel?) Issues
Old Sep 6, 2013 | 12:08 PM
forfakes's Avatar
** NOTE ** I did try the search button and couldn't find my specific issue, sorry if I suck at searching.
Specs: 2002 Tacoma 4x4, 3.4, 1680k Miles
Issue: Cold engine (regardless of weather) start-up is rough and dies every now and then. The issue ONLY happens when my gas tank is about 3/4 full. I've been keeping track of this because I did stumble upon a post that mentioned gas (and for the life of me I can't find it) and it's pretty consistent. Less than about 3/4 full and no issues. More than 3/4 full issue re-appears.
This issue does not re-occur when the engine is warm regardless of fuel levels.
Attempts: Replaced fuel filter.
Please help and thanks in advance.
Old Sep 6, 2013 | 12:58 PM
wyoming9's Avatar
Red face
At this time is the MIL on??
If so what codes are you getting
So this happens ever time you fill your tank till it drops below 3/4
When it does start does the idle go up like it should??
Till it warms up??
I am thinking coolant temp sensor but that most times causes a code.
Old Sep 6, 2013 | 01:08 PM
forfakes's Avatar
No MIL, haven't tried connecting a computer to read codes anyway.
It's been happening every time consistently for the last couple of months.
Idle's just fine after it's warm.
Till it warms up??
Old Sep 7, 2013 | 07:18 PM
wyoming9's Avatar
Red face
It sure sounds like the idle air valve is not working like it should could be the coolant temp sensor poor connections
The fact the MIL does not trip is interesting
Old Sep 8, 2013 | 06:09 PM
raretaco02's Avatar
My 3.4 was doing the same thing and I cleaned my mas and it fixed it. It would stumble ,miss and a lot of times die. But it straighted out during warm up mine was not throwing any codes either
Old Sep 8, 2013 | 06:12 PM
raretaco02's Avatar
It could very well be your temp sensor like Wyoming9 said
jbv808
Aug 6, 2021 04:47 PM
Road Bull
Oct 10, 2015 04:55 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
smiley52
Jul 11, 2015 05:16 AM
Cplmike
Jul 8, 2015 08:47 PM
