Stripped Exhaust Bolts
Old Jan 6, 2008 | 04:23 PM
MattNuge's Avatar
Ran into a snag with my engine removal, I stripped an exhaust nut (on the manifold) and can't get it off. Tried an EZ out, tried liquid wrench, tried WD-40, tried heating it with a torch, tried smacking it with a hammer, not such luck. Any ideas???
Old Jan 6, 2008 | 04:33 PM
4unner4life's Avatar
can you weld another nut on it?
Old Jan 6, 2008 | 04:35 PM
dallison's Avatar
i have used this with decent success
http://www.sears.com/shc/s/p_10153_1...yword=bolt+out
if it is too far gone,
you may have to drill it out and retap it. if you have to, make sure it is straight
Old Jan 7, 2008 | 02:49 PM
Paulsky's Avatar
Any spots you can file straight? Then a 6 point box wrench with heat or impact wrench.
Old Jan 7, 2008 | 04:08 PM
toy_tek's Avatar
Cut the nut off with a cutting wheel, remove the manifold, then replace the stud.
Old Jan 7, 2008 | 05:58 PM
MTL_4runner's Avatar
Either torch the nut off or use a cutoff wheel.
Both ways you'll need to replace the stud anyway.
accuracy
Aug 6, 2015 12:32 PM
upongame619
Aug 1, 2015 12:12 AM
pyramid
Jul 30, 2015 10:05 AM
Dakotaneu
Jul 27, 2015 12:03 AM
Hiluxtrucha
Jul 22, 2015 10:00 AM
