Rattle in clutch? 91 2.4 4X4
Old Jul 27, 2004 | 09:45 AM
Yoda's Avatar
Friend has a 91 Xcab PU, 2.4L, 5 spd.
He had a slight rattle that would go away with slight pressure on the clutch pedal. He changed the clutch, PP, TO bearing, and pilot bearing with a centerforce kit, also new master and slave. He was surprised to find it still has the same noise. What could this be, or is it normal?
I did not see any of the components, or participate in the project, so all I know is what I can see from the outside.
Any suggestions?
Old Aug 5, 2004 | 02:35 AM
the_supernerd's Avatar
If the noise stops when the clutch is in, then it might be something in the transmission because engaging the clutch would stop the transmission from turning assuming that the vehicle is not coasting anywhere.
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
