Question about truck beds for a '99 Tacoma Ext....
Old Feb 3, 2006 | 05:43 PM
KillClock's Avatar
Question Question about truck beds for a '99 Tacoma Ext....
I recently hydroplaned and smashed the driver side part of my truck bed.
Question is... someone told me that truck beds also come in parts. Like the driver side/bed/passenger side are bolted together? Is this true? Cuz I might be able to get away with just replacing the side instead of replacing the whole bed... unless luck is with me and I find a truck bed cheap.
Any helped will be greatly apprieciated. Thx in advance.
Old Feb 4, 2006 | 03:14 PM
KillClock's Avatar
*bump*
Old Feb 11, 2006 | 10:18 PM
KillClock's Avatar
Found out you can buy just the bed wall. Anyone have any good leads for the $$$ challenged on finding one?
Old Feb 12, 2006 | 07:25 AM
Radyota's Avatar
Maybe you could find a used box that was hit on the passenger side that still has an intact driver's side. Buy/remove the whole box and drill out the spotwelds attaching the bedside to the bed. It's better to use an actual spotweld cutter bit instead of a regular drill bit.
Old Feb 13, 2006 | 10:02 AM
KillClock's Avatar
Thx for the reply... now then... would I have to reweld the wall back? I can't weld Looks like I might have to take it in.
Old Feb 14, 2006 | 12:25 PM
Radyota's Avatar
Yup, it's gotta be spot-welded back on. You could get an estimate of the job from a body shop, then compare the cost against replacing the whole box with either good used or new (or aftermarket?) to see which is cheapest.
Old Feb 16, 2006 | 07:47 PM
KillClock's Avatar
Thx for your help... its apprieciated.
matrad
Aug 26, 2024 08:21 AM
GreenLion
Jun 7, 2021 10:49 AM
4x4-runner
Feb 26, 2017 06:42 AM
PureTacoma_Tundra
PureTacoma_Tundra
Jun 29, 2015 09:45 AM
