over heated
Old Sep 15, 2017 | 10:29 AM
chicagopetedagreek1's Avatar
over heated
97 4rnr 6 cylinder reservoir cap popped off & antifreeze is light brown when it overheated, no white smoke from exhaust no antifreeze in oil, could it be trans. oil in radiator, & what would cause this? also trans. started shifting funny, its an automatic ..thanks for any help, Pete
Old Sep 15, 2017 | 11:24 AM
Jomoka's Avatar
Check the transmission dipstick, see if anything looks funny thee. Usually when the trans cooler links they call it the 'pink milkshake' - because the red ATF mixes with the coolant. It's possible you had burnt looking brownish fluid? This happens because there is a transmission cooler/warmer (when the trans is cold) built into the lower tank of the radiator. This can crack over time, one of the few problem areas on a 3rd gen, and it usually makes a mess in the engine and can ruin a trans in fairly short order.
You might also try soaking a white paper towel in the coolant, see what the oil looks like when it soaks in.
Old Sep 15, 2017 | 01:11 PM
Paper towel was dark brown & was low on fluid, so basically a new radiator, antifreeze, 7 transmission filter & oil change should get me up & going again?....Jomoka
Old Oct 2, 2017 | 09:10 AM
75w90mantraN's Avatar
New fluids first for both systems and trans filter. Unless rad is confirmed with leaks, I wouldn't replace it yet. May need to check your hoses, water pump, cooling system for leaks. If coolant level is still low, may be a tiny head gasket leak without the white smoke, perhaps?
If oily presence in the rad, then yes, another indication to change radiator.
