OME 890's & 891's - height difference?
Old Feb 9, 2004 | 08:11 AM
goldtaco9's Avatar
So I got my OME stuff and I was taking a peek at what I bought.
For the rear I got both a set of 890's & 891's to see which will work better for me. I pulled the 890's out of the boxes and they are marked driver and passenger sides and the driver's side is longer as I expected.
The 891's however, both appear to be about the same length. I know that many of y'all have 891's on the rear. Should there be a noticable difference (eyeballing it) in height for the left and right or is it something that I will need to measure to notice?
Thanks,
Mike
Old Feb 9, 2004 | 08:29 AM
waskillywabbit's Avatar
Re: OME 890's & 891's - height difference?
Thanks,
Mike
On my 891s there was a noticeable difference in height when the two were sitting side by side eyeballing it. There are some actual dimensions I took for Billy on some thread on here. I'll look for it and post it if I can find it.
EDIT: Try this thread - https://www.yotatech.com/forums/show...OME+dimensions
You going to install the stuff yourself? It is pretty easy. Check out my website for some simple write-ups.
CLICKY
I just got finished with mine less than a month ago. If I had known how much better the ride was going to be I would have made the OMEs my FIRST mod hands down.
Old Feb 9, 2004 | 01:44 PM
goldtaco9's Avatar
Thanks.
I took a good look at them again and the 890's are marked PS & DS and there is a readily apparent difference in height.
The 891's are marked R/H & L/H and the height difference is much less. Also the R/H is taller. I am guessing two things:
1. The 891's are marked wrong for the USA.
2. The variance in the difference of height is due to the fact that the 890 is a softer spring and needs to be a wee bit longer (than the other 890) to make up for that, if you know what I mean.
Thanks again,
Mike
Old Feb 9, 2004 | 01:49 PM
891
Thanks.
Thanks again,
Mike
1. YEP
2. Makes sense
Just ignore the labeling and put the longer 891 on the driver's side/gas tank side.
Old Feb 9, 2004 | 01:51 PM
goldtaco9's Avatar
Yup. That's what I'll do.
If I can find a warm place to work, I will do this myself. If I can not find a place, I will either wait until Spring or, gasp, pay someone.
Mike
Old Feb 9, 2004 | 04:58 PM
MTL_4runner's Avatar
I think you are the first person to buy both and try them so I will be all ears when you finally get around to putting them in and give us your feedback on which rides better!
nvdesertrunner
May 11, 2020 08:18 PM
4x4-runner
Dec 27, 2016 01:58 PM
accuracy
Aug 4, 2015 08:05 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
4Runnin2000
Jul 29, 2015 06:09 PM
