Looking to get some opinions about an oil leak I have. The leak is right above the oil pan (it is not the oil pan, I've replaced the pan and sealed it correctly with FIPG), and it occurs a good 20-30 seconds after the car has been started. It’s leaking pretty bad.
One more thing to note is that I dropped the oil pan and noticed a small half an inch crack in the oil pump assembly. Not sure if it goes through all the way. It could also just be a casting mark..I really need some guidance.
Here’s a photo of the leak
