nooobie 92 back window problems
Old Jun 26, 2003 | 09:35 AM
Jays4Runnin's Avatar
Unhappy nooobie 92 back window problems
My 92's back window has mysteriously stop working i hit the button and i hear the motor, so i dont think its a fuse, i just need to get a look at it to se the problem, any pointers??
stuck w/o air
jay
Old Jun 26, 2003 | 10:15 AM
TOR
Back window problems
Send me your VIN or your make and model and I will quote you on the switch and relay. Generally that is what it is on those issues.
Todd
Old Jun 26, 2003 | 10:26 AM
thanks so much its a 92 4runner sr5 3.0 v6
Old Jun 26, 2003 | 10:57 AM
TOR
Parts
Switch: $43.90
Relay: $248.88
Add $10 to either of these if they turn out to be the problem and that is what it would be to have them at your front door. I doubt it is the relay though or else you wouldn't be getting power to the motor. However we have had a situation or two where that did happen. Normally it is the switch but not the switch you press to roll the window up and down. Let me know what you find out on it and if you need anything.
Todd
Old Jun 26, 2003 | 05:38 PM
toddowaddo's Avatar
I just had this problem on my '86 4runner. I chased my tail around for 3 days and finally discovered the problem. It was the rear wiper not all the way up, I guess there's a cut out switch somewhere in the wiper. That would be pure dumb luck if you had the same problem, but it's worth a looksy.
Todd in N.C.
warrenjcarlson
Jul 22, 2016 11:47 AM
toyota32
Jul 6, 2015 05:42 PM
aciorba23
Jun 29, 2015 04:18 PM
