Loud noise when reversing in 4x4 under heavy load in 3rd Gen 4Runner
Old Apr 29, 2017 | 01:03 PM
c4RunnerSR5's Avatar
Hello, new guy here. Owner of a 1999 4Runner SR5 3.4 V6, automatic transmission.
I currently have a problem with my truck. When reversing in 4x4 and under heavy load there is a loud squealing type noise. Someone outside of the truck said that it came from the rear or middle.
There is no noise when I reverse in 4x4 on a plane surface.
In 2wd everything is normal as well.
Help would be greatly appreciated.
Thanks
Old Apr 30, 2017 | 03:56 AM
Flash319's Avatar
Id be looking at front drive shaft transfer case area. Reverse under heavy load is not a very good thing to be doing. The torque is twisting everything causing the t-case and diffs to twist with the driveshafts as well. I bet something is rubbing.
Old Apr 30, 2017 | 06:19 AM
Thanks for replying. I will look into it.
Max OOOO
32
Dec 8, 2009 06:06 PM
