Loose Front End
Old Nov 18, 2005 | 12:58 PM
4SKINNER's Avatar
Loose Front End
I have a 91 4runner, v6, sr-5
Yesterday I had a Downy Suspension Package put on... HD rear springs, new shocks, and torsion bars... I was expecting a stiffer ride but the front end seems to be a little loose (alot of play in the steering wheel) and the springs were supposed to level the ride (which it still sags a little)... I also had 31's put on this time (previously had on 225's)....
now to my questions... Is the loose front end because of the bigger tires and stiff suspension or is it because there isn't something quite right with the torsion bar settings.... and should I still see the sag?
Thanks,
Old Nov 18, 2005 | 01:08 PM
4SKINNER's Avatar
One more thing... can the front end be dropped a little bit by adjusting the torsion bars?
Old Nov 18, 2005 | 01:16 PM
ebelen1's Avatar
Thanks,
I've read that people with the 2nd gen runners have normally had play when the steering stabilizer went out. Try searching under this.
I have a 3rd gen and had similar issues after buying new tires. I had an alignment done but it was not done right. This cause a lot of looseness in my steering. After getting this fixed, no more play in the steering.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
