Just installed the Optima Red Top in my 02 Tacoma.
Old Feb 9, 2005 | 10:02 PM
P. Bauer's Avatar
My stock battery was starting to lose life (hard to start on cold mornings). I've had a Optima Yellow Top in my S4 for a year and I'm very happy with it.
Install was pretty straightforward. You need to use the supplied spacer if you want to retain the stock hold-down. I had to extend the + Red wire by using a 10" extension (because I used the 75/35 model).
If you happen to find the 34R (reverse) model, you won't need the extension.
I'll post pics later if people want to see them.
Old Feb 10, 2005 | 12:42 AM
weldpro's Avatar
I have always been very happy with the RED tops. I have done some serious winching, and welding (using a ready welder), and it keeps on going!
Richard
Old Feb 10, 2005 | 04:34 AM
Bumpin' Yota's Avatar
The RED top is a very good battery if you dont overload the alternator. It can start damn near anything at any ambient temperature... But if you ever do start using significantly more juice than the alt can supply, you might want to consider jumping over to the yellow or blue top. I've used and promptly killed red tops doing that with my system...
BushPig
Oct 29, 2022 06:26 AM
coryc85
Sep 9, 2015 06:24 AM
Sep 4, 2015 09:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
crashburnoveride
Jul 10, 2015 06:39 AM
