I was thinking of putting 04 tundra rims on my 97 runner. It should work right?
Old Jan 14, 2005 | 03:04 PM
rytek's Avatar
The Tundra rims are 17x7.5 with a 17mm offset (the 5 double spoke ones) and my runner is not lifted yet. But for only a little wider and a +2 offset, it shouldn't have any rubbing would it?
Old Jan 15, 2005 | 12:21 AM
NorCalVP's Avatar
they'll fit just fine...
Old Jan 15, 2005 | 12:33 AM
jimbo74's Avatar
the rims will fit without an issue, however depending on what tire size you are running currently and proposed, you will need to check on if there will be rub or not....
Old Jan 15, 2005 | 01:40 PM
rytek's Avatar
The tires will be 265/65/17, the stock tires from toyota.
Old Jan 15, 2005 | 03:21 PM
jimbo74's Avatar
that wasnt the question i was trying to ask... what i mean is that the nex X wheels have a certain size tire that is a 265/65/17 -- how does that compare size wise to the tires that are currently on your truck? yes they may bolt on fine, but if the new tires are larger or smaller then the current ones is where you might have a rubbing issue
Old Jan 15, 2005 | 04:27 PM
NorCalVP's Avatar
That is the exact same combo i have on my 96 4WD. Fit's fine with no rubbing. The 265/65/17's are just a hair smaller than the stock 265/70/16's. but not enough to notice a difference in the speedo.
They will bolt right up with no problems.
toy89yota
Jun 24, 2015 01:18 PM
gog1968
Jun 22, 2015 05:55 AM
95Runner
7
Jun 8, 2002 01:02 AM
94 First Responder
Jun 6, 2002 02:19 PM
