Head Gasket Question
Old Feb 16, 2008 | 04:29 PM
RCFJ40's Avatar
Well I'm a noob to this forum and I have a tech question. Other than checking the dipstick for radiator fluid mixed in with the oil, is there another way to check for a blown head gasket or a leaking one on a 99 Toyota 4x4 with a 2.7L I4. Someone told me that if you take the radiator cap off and rev the engine, if coolant shoots out then you have a head gasket leak just wanted to see if that was true thanks for your replys.
Old Feb 16, 2008 | 09:15 PM
Caffeine's Avatar
I'd say that almost every engine will shoot coolant when you rev the engine. The only only obvious signs that I know of for a blown headgasket is exhaust that is white and smells kind of sweet. Coolant levels that drop, or oil in your coolant also are signs of course.
Old Feb 17, 2008 | 12:56 AM
Adam F's Avatar
You can buy a chemical test kit that checks for the presence of combustion gasses in your coolant.
Old Feb 17, 2008 | 02:43 AM
85 PICKUP's Avatar
Take it to a shop and have the engine pressure tested (I believe it is a cylinder leakdown test or something) Shouldnt be more than and hour of labor and worth it for peace of mind and salvaging your engine.
Old Feb 17, 2008 | 06:54 AM
RCFJ40's Avatar
Great I'll go to the dealership and have them do the leakdown test thanks 85pickup and thank you to everyone who responded. If the gasket is leaking or blown I guess I'll have a good thread to post on the rebuild LOL.
Old Feb 17, 2008 | 08:09 AM
keithguts's Avatar
A dealership, you sure you want to do that?
Old Feb 17, 2008 | 05:11 PM
MTL_4runner's Avatar
Check your coolant hoses.....if they are very hard after the engine heats up, you could have a blown HG.
the1998sr5
15
Jul 14, 2020 08:35 PM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
