got a problem from the wreck
Old Oct 19, 2008 | 01:27 PM
james4060's Avatar
so my truck still isn't fixed. i have replaced the upper control arm and ball joint, but the tire is still rubbing on turns and the drivers side front tire is two inches farther back than the other side. i will try and post pics in the next hakf hour, but any suggestions to why this is?
Old Oct 19, 2008 | 01:42 PM
DudeBud's Avatar
frame rail pushed back
Old Oct 19, 2008 | 06:02 PM
98runner210's Avatar
best bet is to take it to an alignment shop where they can check the geometry of things. They should be able to tell you exactly what is bent. I'd do this if you arent able to tell just on a visual inspection.
Old Oct 19, 2008 | 08:41 PM
racermp's Avatar
maybe spindle, take it to an alingment shhop. measure the frame from arm to some point after the arms on both sides.. both sides should be the same
RyanV
May 14, 2016 08:24 AM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
bryan34w
Jul 6, 2015 05:53 PM
