Fuel line fittings size 3.4L
Old Aug 22, 2005 | 05:31 PM
bosco659's Avatar
Does anyone know the size (diameter and pitch) of the inverted flared fittings on the end of the fuel supply line to the fuel rail on a 3.4L '00 Runner. The fitting I'm talkig about is located forward of the brake booster and connects the fuel line to from the fuel rail to the hard line to the fuel pump / tank.
Another fitting size question - I believe the banjo bolts on the fuel rail are 10mm diameter but what is the pitch - 1.00 or 1.25?
Thanks for input.
Vic
Old Aug 23, 2005 | 03:19 PM
bosco659's Avatar
Anybody?
Old Aug 23, 2005 | 06:08 PM
HappyPills's Avatar
Is your line kinked or any other reason your replacing them or is it something else?
Old Aug 23, 2005 | 06:41 PM
bosco659's Avatar
I plan to install a fuel pressure regulator at this connection and do away with the stocker. I also plan to install a fuel pressure gauge on the fuel rail using a double length bajo bolt.
smthwsn357
May 1, 2024 07:28 AM
Whatever123
Sep 30, 2015 12:12 AM
Sep 4, 2015 09:27 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
