Front Struts 95 Tacoma (Stumped the Parts Guy)
Old Aug 26, 2009 | 02:32 PM
kporter's Avatar
1995 Tacoma 4 WD ADD. I am trying to change out my front shocks/struts. On the new shocks, purchased from the local parts store, the dust cover is a seperate piece. On the original shock, it (the dust cover) is part of the shock. The problem arises in that the new dust cover is a little larger in diamater (about 1/4 inch) and won't fit through the spacer at the top of the strut. The parts guy couldn't help me. He said that is the one his system calls for. Any suggestions?? Do I need to get them from the dealer??
Old Aug 26, 2009 | 02:43 PM
Tubbyfatty's Avatar
You will probably have to go to the dealer.
Alot of "oem" replacement parts dont match up exactly. My friend got a rad that said it was "a direct oem replacement" and it didnt fit right and the A/T line connecters were a different size.
Old Aug 26, 2009 | 02:44 PM
DeathCougar's Avatar
Obviously was giving you the wrong part.
Or, a cheap aftermarket part.
Take it back go to the dealer, and get the correct part the first time.
Old Aug 30, 2009 | 10:44 AM
eddieleephd's Avatar
Wheelersoffroad.com or call toyota and get the part #
Old Aug 31, 2009 | 12:20 PM
J-Ball's Avatar
I put Rancho shocks on my 95.5 Taco, no regrets. All worked as it should. I would NOT go to the dealer and get OEM struts. Upgrade man, you'll be glad you did and won't cost much more if any. Do it!
Old Aug 31, 2009 | 05:33 PM
pmbazus's Avatar
You don't need the dust cover. Install the shocks without the dust cover. That is how I installed my Bilstein 5100's.
ACZR
Jun 23, 2015 07:55 PM
slider417
Jun 22, 2015 10:18 AM
UKMyers
11
Jun 24, 2002 05:41 AM
