Diff Drop question
Old Apr 15, 2010 | 06:22 PM
trollcruiser's Avatar
Diff Drop question
Just wondering why someone hasn't made a bigger diff drop than 1"? I think there is room for 1/2" more and that would maybe allow 3"-3.5" in the front. Just hoping some of the suspension gurus can answer this.
Old Apr 15, 2010 | 06:24 PM
Yukon's Avatar
Diff drops dont really do too much. There is another mount for the diff, on the X-member. A 1 inch diff drop really only drops the diff a half inch or so
Old Apr 17, 2010 | 04:49 PM
Gerdo's Avatar
Read this https://www.yotatech.com/forums/f2/d...angles-137503/ my post (#21) explains the diff rotation/drop measurements
Old Apr 17, 2010 | 05:59 PM
LarsDennert's Avatar
If you have ADD you can't drop more than an inch because the ADD solenoid will contact the cross member. I've had good results from the diff drop. I'm running TRD Tundra springs + a 1" Top out spacer, long travel OME struts and Camburg arms. 10.5" of wheel travel. The tulip joints are at max angle at full droop.
Old Apr 17, 2010 | 06:09 PM
Thanks. I knew the diff didn't drop the full inch because of the other mount that it rotates on. I did not know that the ADD would hit, just never looked at that. I already have the diff drop and was just asking a hypothetical question. What is the general concensus on the max amount of lift with the diff drop installed?
jaretstuff
Aug 4, 2015 02:08 PM
coffey50
Jul 28, 2015 10:55 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
scottyg486
Jul 19, 2015 05:34 PM
