Crank pulley (Harmonic balancer) bolt hole for puller size??
Old Nov 27, 2007 | 01:53 PM
kcebes's Avatar
I have a harmonic balancer puller to try and get my crank pulley off. I'm in the middle of a timing belt change. The pulley won't come off freely. (Yes the 19mm bolt is removed lol) What size bolts do i need to attach the puller to the pulley? I've tried two kits and neither had the right threads! Help!!!
Old Nov 27, 2007 | 02:08 PM
kcebes's Avatar
UPDATE: A friend just got back to me and said it's either 8 or 10 x 1.25. Can anyone verify this? I think i have the 8's so maybe i'll just buy a few 10's.
Old Nov 27, 2007 | 04:33 PM
GSGALLANT's Avatar
They are 8mmx1.25. You'll need bolts long enough to reach the very back of the pulley, because only the rear part of the holes are 8mm and threaded (maybe the last 1/4" or 3/8" at the back of the holes). The front end of the holes are 10mm (or just under, because a 3/8" bolt fits in there) and are not threaded. The front part of the holes are used to insert the crank pulley holding tool, when removing or installing the crank bolt.
Old Nov 27, 2007 | 05:58 PM
MTL_4runner's Avatar
Ditto.....and hopefully they aren't rusted at all.
Put some antiseize on the crank nose when you go to reassemble.
Old Nov 28, 2007 | 03:41 AM
kcebes's Avatar
Ugh...so i just didn't stick the bolts in far enough to find the threaded part! Thanks for the help!!!
Old Nov 28, 2007 | 08:16 AM
GSGALLANT's Avatar
Don't beat yourself up... it's a common mistake! Good luck with the rest of the job. Make sure you get the crank bolt torqued back up properly to 217 ft-lb (I also used blue loctite on the crank bolt threads to give me a bit more assurance that it won't back out). Take your time putting the belt back on and make sure you're timing marks are all lined up properly before closing everything back up. Other than that, you should be good to go.
coffey50
Jul 28, 2015 10:55 AM
v_man
Jul 23, 2015 04:01 PM
dropzone
Jul 16, 2015 02:00 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
