Crank bolt
Old Oct 11, 2017 | 03:18 AM
fierohink's Avatar
Crank bolt
can you use the starter trick to break the crank bolt loose on a 5VZ like you do on a 22RE?
Old Oct 11, 2017 | 07:30 AM
Marc's Avatar
Yes you can.
You still need a holder to torque it down properly though.
Old Oct 11, 2017 | 07:56 AM
aowRS's Avatar
I fabricated a pulley holding tool last year in order to do the timing belt, etc. on my 4Runner. It's about 3' long and has two pins that engage holes in the crank pulley. Worked perfect to loosen & tighten the crank bolt.
You're welcome to borrow it - I'm in Ellicott City.
Andreas
Old Oct 11, 2017 | 08:31 AM
fierohink's Avatar
Andreas
I might take you up on that!!! Shoot me a text and we can work on arrangements
412-389-1974
Old Oct 11, 2017 | 08:34 AM
75w90mantraN's Avatar
That is a fine tool.
Old Oct 23, 2017 | 08:00 AM
aowRS's Avatar
412-389-1974
Dan,
Nice to meet you today. Hopefully my bush-league welding holds up when you bring the crank bolt to torque.
Andreas
