Clutch replaced but soft pedal
Old Oct 9, 2003 | 09:37 PM
Yoter's Avatar
Guest
Question Clutch replaced but soft pedal
Hey I helped my buddy replace his clutch today in his 95 Runner. We got it all done and I think it feels fine but he is sure it is not as good as it could be. I tried to bleed out the cylinder but no air came out. Is it in his head or is there maybe an adjustment I could help him with to get more pedal. The clutch we installed in it is a Center Force one and we had the flywheel turned if that helps. Thanks guys, Blue
Old Oct 10, 2003 | 03:55 AM
PirateFins's Avatar
Re: Clutch replaced but soft pedal
Originally posted by BigBadBlue
Hey I helped my buddy replace his clutch today in his 95 Runner. We got it all done and I think it feels fine but he is sure it is not as good as it could be. I tried to bleed out the cylinder but no air came out........
Which cylinder did you try and bleed? Master or slave? Did you bleed it like you would do the brakes, by pumping it up 10 or so times and then holding it?
I had a similar problem when I replaced my clutch and It ended up being air in the line down at the slave cylinder. Hope that helps.
Old Oct 10, 2003 | 09:40 AM
Yoter's Avatar
Guest
Re: Re: Clutch replaced but soft pedal
***I bled the clutch master cylinder being we did a clutch job.***
***I had him pump it about four times and then checked it. We never took the lines off nor lost fluid so I assumed it was ok***
***I will do it like you said here and see what happens. Thanks***
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
coryc85
Jul 6, 2015 04:07 AM
