Bilstein shock parts--order?
Old Sep 13, 2003 | 10:19 AM
Toyo4x4's Avatar
Looking at the parts bag, I see 2 dull metal disks, 2 rubber bushings, 1 silver metal disk, and a nut. Would this be the correct order from top of shock to bottom: Nut, silver disk, dull disk, bushing, (truck bracket), bushing, dull disk, (shock)?
Do any of the stock parts need to be used for the top of the shock?
Is there a specific torque they need to be tightened?
I can't believe they don't put in even a basic sketch for installation!
Old Sep 14, 2003 | 02:16 PM
kaiberg's Avatar
not sure what your talking about really with the shiny and dull disks....but it should go from the shock up: shock, washer, bushing, frame, bushing, washer, nut...as regards torque...just tighten nut until the bushing starts to sqeeze a bit...not til you squeeze it down flat...just when it starts to squish...hope this helps...or maybe you already got em on and are enjoying your new and improved ride
Old Sep 14, 2003 | 08:25 PM
Toyo4x4's Avatar
I was looking in the Haynes manual ( ) and it showed 4 washers. The Bilsteins only came w/ 3. I went to look at the truck and felt over the top lip of the bracket, only 1 up top and 2 on bottom. I thought there were supposed to be 2 on either side. I've got it figured out. Stupid Haynes manual. Beginning to think I wasted $15.
The stock order on the truck from shock up is: washer, bushing, washer, bracket, bushing, washer, nut. I guess Bilstein wanted the top washer to be the shiney one for show (YEAH RIGHT....ON A 4X4????)
Any idea on what the torque specs are on lower front bolts and all the rears?
ladybugRC
458
Aug 21, 2020 10:41 AM
ZGjethro
Jun 7, 2017 11:04 PM
dirk89
Oct 1, 2015 05:15 PM
ktm192k
Oct 1, 2015 08:47 AM
toyotasaurus
Sep 24, 2015 03:30 PM
