automatic transmission flush?
I have 2002 4wd 4runner. I going to attempt to flush the transmission. I know that the system capacity is around 15 qts. I drained 5 qts out of the pan. I also changed the filter and refilled the pan with 5 qts. Now i am at the point of actually flushing the system. Now, do i need 10 more qts. since i have already added 5 qts., or do i need to flush with 15 qts? Does the fluid i replaced after the filter change mix with the old fluid? Also, does the return line come out of the bottom of the radiator on the drivers side?
Thanks,
Jeremy
Thanks,
Jeremy
FS[PacSouthWest]: FS: A340 transmission and t/case Lancaster Ca
4x4-runner
Dec 27, 2016 01:58 PM
BeMiceElf
Oct 10, 2015 09:40 PM
