4runner tail light LED problem
Problem: All three of my brake lights do not work (do not get brighter when I apply the brakes). The two lower led tail lights (20 leds, 0.5 watts/led) did not work at all when I initially plugged them in, but I realized by piggybacking a load resistor on both of the green wires that they would turn on. Leaving the white wire with a black stripe untouched. ALSO, my front parking/driving lights turn on when I apply the brakes
(noticed this when I had my headlights off). Also my high brake led worked fine when I hadn't plugged in the two lower tail/brake led's.
Any help is much appreciated!!
(noticed this when I had my headlights off). Also my high brake led worked fine when I hadn't plugged in the two lower tail/brake led's. Any help is much appreciated!!
Scotttekoch
23
Nov 1, 2021 12:41 PM
