4Runner makes a funny noise when I turn on the AC
Old Sep 3, 2008 | 10:17 PM
Rspct2All's Avatar
Just today, I turned on the AC for the first time this summer.
(I usually drive with the rear window down and the front windows opened.)
When I turned on the AC on Low, the 4Runner was making some funny noise. The noise sounded like there were a bunch of cans under the car being dragged.
QUESTION:
Is the compressor dead? or do I just need to recharge it?
No leaks can be seen, in terms of oil.
I don't know if the AC has been recharged before I bought the 4Runner used in May 2007.
The AC used to work before, but I haven't used the AC for almost 3 months since the last time.
Thanks for your time!
Old Sep 4, 2008 | 03:01 AM
wjwerdna's Avatar
hmmm... definitely should use it at least once a month, may be bad. check your belt tension?
Old Sep 4, 2008 | 03:02 AM
crolison's Avatar
Mine makes squeeling noises when i don't use it for a while, it sounds like a stuck pig
Old Sep 4, 2008 | 07:34 AM
Rspct2All's Avatar
Thanks for the advice guys. I will use it at least once a month from the moment I fix it. And I have checked the belts, so it does sound like a stuck pig, thanks!
Old Sep 4, 2008 | 08:07 AM
tommytuttle's Avatar
doesn't yours come on when you use the defrost setting? clearing up the windshield?
Old Sep 4, 2008 | 10:17 AM
Ron Helmuth's Avatar
it does get used but does not indicate same
Yes the AC is triggered in the last 2 of the manual switch defrost settings-but in mine it does not trigger the A/C indicator light.
I have been using those settings for "budget Air Conditioning" and it will keep me cool enough to make about a 10 minute trip.
Old Sep 4, 2008 | 07:04 PM
Rspct2All's Avatar
Update On The Ac Making Noise
Double checking the belts again today after work, I found out that the belt which drives the AC Compressor is LOOSE! wth? HOW DID IT GET LOOSE? Dont know, but I'm going to my mechanic tomorrow after work. It's got about a 1 inch loose travel up and 1 inch down. Pretty dang loose!
Would you guys think it's the Compressor or just the belt this time?
Fingers crossed that it's just the belt...
Bamripzit
Jul 19, 2015 01:17 PM
Bamripzit
Jul 13, 2015 07:21 PM
camdenbuck
Jul 7, 2015 07:33 AM
Mr.Black
Jun 21, 2015 10:17 AM
