Vehicles - Parting Out Parting out a vehicle, post it here
WTB[SouthEast]: Fuel sending unit
Old Nov 20, 2016 | 10:49 AM
85 FF / medic's Avatar
Fuel sending unit
Need a fuel sending unit for a 85 4Runner 22RE with the 14 gallon tank. Toyota no longer makes the part for the 14 gallon tank.
thanks!
Old Oct 20, 2022 | 06:27 AM
PickleRick81's Avatar
Not sure if this helps or not but there are universal Marine fuel level sending units. I realize they will not have the same ohms as your dash gauge. There is a converter box, a cheap china one (I'm using) and a more expensive one. I'm running my Passat diesel gauge cluster in my 87 Toyota with the original fuel sending unit and am using the small converter box installed behind the ECU kick panel to make them work together. It's fully adjustable, my Passat was the complete opposite ohm reading from my Yota. I tried setting it with resistance using a multi meter but watching the gauge as I moved the level was more accurate. I now read empty at a 1/4 tank.
The slide style fuel sending units are more accurate than the lever style.
85 FF / medic
Nov 19, 2016 06:58 AM
mick.j.becker
Dec 9, 2012 01:32 PM
lctmjw
17
Aug 29, 2011 06:39 PM
ToyYoda
Mar 30, 2009 06:41 AM
