FS[PacSouthWest]: 85 2WD chassis/driveline FS
I have a complete rolling chassis from a 1985 Toyota SR5 Extended Cab for sale.
Comes with the engine, trans, rearend, harness, steering column, seats and interior parts. The wheels are OG Rikens with good tires.
The engine will need a headgasket as it just started giving a little white puff from the exhaust. There are many new parts that have been installed in the last 7000 miles. If I break it down the engine will come with the complete harness, airbox and tube.
The transmissin is a 5 Speed and in good working order.
Newish parts are
Fan clutch and fan
Cam chain cover and heavy duty chain kit with steel guides
Oil and waterpump
EGR valve
Fuel Pressure regulator
Crank Dampner
Rad Hoses
Shocks
Rear brake cylinders
Rad was flushed and is in good shape
Clutch master and slave cylinders
Gas tank
Fuel pump and sender
I have a new Driveshaft mid bearing
The interior is brown and there are a few good parts that are not cracked from heat/age
The steering column is in good shape. It is a low mileage truck so the tilt is tight and ignition works well, has keys
the seats will need new foam and covers. Door panels and column cover are gone.
The chassis has a receiver type hitch. The truck was not crashed. It would be a good start for someone wanting to do a EFI conversion or doing a straight axle swap or lowering project.
$600.00 takes it all.
If it does not sell as a whole unit this weekend I will be parting it out.
Located in Sunland California
661-607-3125
I will have interior parts pictures when Its light out
[/QUOTE]
Newish parts are
Fan clutch and fan
Oil and waterpump
EGR valve
Crank Dampner
Rad Hoses
Shocks
Gas tank
661-607-3125
[/QUOTE]
