Other Makes Cars/Trucks Own a different car or truck other than a Toyota?
91 Camry 2vz-fe V6 harmonic balancer
Old May 23, 2015 | 02:17 PM
yotatoda's Avatar
If you've ever tried to find a harmonic balancer for the ES250, or the v6 toyota you'll know their nearly impossible to find and when you do, get ready to bend over. So here's what I did. I pulled the pulley off an 87 camry 2.0 liter 4 cylinder and compared them. There are two differences between the pulleys, the timing mark is in a different location, and the belt size has one rib less. So, set the engine to TDC, File on a new timing mark, with a razor knife carefully cut one rib off the V6 belt and voila, back on the road and running strong.
ChildrenOfBodom
124
Jun 24, 2012 01:17 PM
