Other Makes Cars/Trucks Own a different car or truck other than a Toyota?
1993 Bonneville No spark
Old Aug 27, 2011 | 09:29 PM
rowdy235's Avatar
Hoping there are some GM guys around,
I recently got a 93 bonneville non-supercharged with the 3800 from a good buddy of mine. Backstory is he bought it with a thrown rod in the motor. It did run (badly obviously), but nonetheless it would run and even drive a little bit. He chose to buy an engine from pick-a-part. He got it all put together but it wouldn't start so he gave up on it.
So, it appears to have fuel but no spark, somebody said crank sensors were a common failure? Because they didn't change over sensors or anything, anything could be wrong.
Any help is appreciated
Old Aug 28, 2011 | 04:25 AM
Thelast83inNJ's Avatar
Common crank sensor failure along with its' pigtail. If you could scan it for data, you would see no rpm signal. Should have no injector pulse too. Only crank sensor, ignition module, and ecm for spark. You may need a different crank puller to pull off I think.
Old Aug 28, 2011 | 08:18 AM
rowdy235's Avatar
I have a manual and it does look like a PITA to do lol. Its OBDI so can't really scan it. I did find a test procedure for it, really needs two people do do it efficiently though, so i will likely try that. Or I may just bite the bullet and replace it. Peace of mind if nothing else, its not really that expensive.
Old Aug 28, 2011 | 09:15 PM
JamesD's Avatar
There is a main ground harness that bolts to the bellhousing. Check for wiring being pinched or unplugged.
James
splangeland
Apr 6, 2024 08:14 PM
ToyotaMD
Sep 22, 2015 04:49 AM
themightykhoner
Sep 18, 2015 02:28 AM
Hugh_Mann
Sep 16, 2015 03:59 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
