High Power LED flashlight Olight M20 Warrior $30 shipped **Sold**
Olight M20 Warrior LED flashlight
-comes with the light, 2 new CR123 batteries, shealth, lanyard and an extra switch cap(button)
$30 shipped from PDX
PM or email
Paypal only
I used this at work for about a month.it has just been sitting in my nightstand.
I have several other Olight flash lights and these things kick butt.
they sell for $55+ on ebay:
http://www.ebay.com/itm/Olight-M20S-...item3373925e70
Olight M20S R5 is the special operation edition of the famous Olight M20 R5 specifically for law enforcement and military deployment. Same as Olight M20 R5, this tactical flashlight produces 320lumens, 306 yards throw and runs 4 hours continuously on max brightness. Unique to this special edition is the additional side switch direct access to strobe when power off and to select output when power on. The additional feature enables single hand operation required by tactical needs of law enforcement and military operations, which clearly set it apart from the rest of tactical LED flashlights.
Note: M20S has the same operation modes as M30
Features:
* Side switch to direct access to strobe when power off or select output when power is on.
* Tactical momentary-on forward switch, protruding switch for easy momentary or click to lock on
* Stainless steel striking bezel and rear striking bezel, both removable
* Rugged, nearly indestructible aluminum body with anti-scratching Type III Mil-Spec Hard
* Low battery indicator: The light will flash to warn you when battery power is low.
* Battery (not included): 2x CR123A, 2xRCR123A, 2x16340,1 x 18650, 1x17670
2.7" (length) x 1" (diameter at body) x 1.4" (diameter at head)
Functions: Three brightness levels plus strobe, 9lm (150hrs)-110lm (12hrs)- 320lm(4hrs),
slight wear on the belt clip
PM or email
Paypal only
Features:
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
FS[NorAtl]: set of 4 ball joints. any torsion bar ifs 4wd
akaphilly
Jul 9, 2015 02:27 PM
