1994 FZJ80 Front axle **SOLD**
Old Mar 17, 2014 | 12:49 PM
04sport4x4's Avatar
SOLD
Front axle from a 1994 Toyota Land Cruiser FZJ80 non elocker, hi pinion 4.10 gears. Complete except for the brake calipers. Rotors nearly new with just surface rust. All ABS sensors and connectors uncut. Knuckles not leaking. Includes both the tie rod and drag link. About 220k on the truck it was pulled from. I did not see it run.
$575 obo
Local pickup only
Location SoCal 90605
Thanks,
John
Old Mar 17, 2014 | 12:54 PM
blake.nemitz's Avatar
can you put mini truck knuckels on these? if you can i might be interested
Old Mar 17, 2014 | 01:14 PM
04sport4x4's Avatar
The FZJ80 knuckles and balls are larger then the mini truck so these are stronger. The wheel bolt pattern is the same as the mini truck. The axle is 63.5" wide which is a nice improvement over the 85 and earlier axles. Just need to work out your steering.
Old May 28, 2014 | 03:22 PM
04sport4x4's Avatar
Still available.
Old Jun 25, 2014 | 12:43 PM
04sport4x4's Avatar
Bump.
Old Jul 9, 2014 | 12:37 PM
04sport4x4's Avatar
Sold...
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
oldirtydirt
Feb 23, 2020 09:30 AM
deepmarsh
Aug 6, 2015 03:44 AM
coffey50
Jul 28, 2015 10:55 AM
