'85 4Runner Wheel Fitment
I'm wanting to put a set of Cragar Nomad II wheels on my '85 4Runner. I was going to use my stock wheels but they are a little to rusty to go on a truck straight out of the paint booth. The reason I want to use these wheels is because they are as close to original looking as I can get since I can't seem to find anyone in NC that will rechrome wheels. The ones I've found are 15x7's with a 12.00 mm offset. My question is will they fit? I'm assuming the stock wheels have a 0 mm offset. Suspension is stock with no mods. Any tips or suggestions would be appreciated.
Here's a link to the wheels
http://www.summitracing.com/parts/cr...760p/overview/
If the stock ones are 0mm offset the 12mm offset are going to be further in the fender i would be worried about them hitting the calipers. Also it you go to a wider tire then you will probably hitting the frame.
Jun 1, 2021 01:51 PM
skoti89
Jul 6, 2015 07:45 PM
