Water under my dash: 04 Taco
Old May 9, 2005 | 07:03 AM
Shiner5's Avatar
This started about a month ago and has gotten worse. When I turn to the left, I can hear what sounds like water boiling under my dash. The sound doesn't happen when I turn to the right. When I turn either direction, I get a stream of water pouring onto my floor under the dash?
Thoughts? AC related.
Old May 9, 2005 | 09:22 AM
rjlem's Avatar
Couple of thoughts;
If you have not been getting rained on or water inside there from washing the truck, the A/C condenser is the probably the only source for the water.
You did not mention it in your post, but I expect since you live in Texas, you have been using your A/C constantly for a while now.
Check your A/C condensate drain hose. The hose may have come undone from the condenser housing or the hose may be plugged.
If nothing looks out of sorts, try going a few days without using the A/C and see it that makes a difference.
Old May 9, 2005 | 09:28 AM
bamachem's Avatar
1. Take it to the dealer. It's under warranty. Let it be their headache.
2. It's more than likely a clogged AC Condenser drain hose.
Old May 9, 2005 | 10:29 AM
boogyman's Avatar
if it's been raining, check the plugs in the firewall, sometimes they can come loose.
YotaPagota
Sep 20, 2015 06:24 PM
LotOMiles
Sep 14, 2015 11:45 PM
TOYOTASC
Sep 10, 2015 05:18 PM
noahstancik
Sep 10, 2015 10:47 AM
--Oz--
Sep 6, 2015 01:06 AM
