Tool item numbers
Old Oct 24, 2003 | 11:01 AM
scott.475's Avatar
Tool item numbers
When a manual refers to a tool number, like "Mainshaft Locknut Wrench T88T-7025-AR", is that something that is only available from the dealership? I was trying to find a tool through Grainger that is like an extremely deep socket, for pulling a flange nut of the input shaft of a transmission, but using a keyword search and part # search, I wasn't able to find anything, even though the part number is referenced in the manual.
Old Oct 24, 2003 | 12:33 PM
Cebby's Avatar
That's gotta be a dealer piece if its in the service manual...
Old Oct 25, 2003 | 11:37 AM
Shane's Avatar
Yep, not much out there about them, but it seems to me that you could make your own easily enough. Just find a cheap socket of the right size, cut it in half and weld some pipe or tube in the middle to give enough length to reach the nut.
Old Oct 25, 2003 | 01:52 PM
scott.475's Avatar
Shane, I like your thinking, I've been trying to come up with the right excuse to give my wife to finally pull the trigger and buy a welder, I think I have found it!
This is for the tranny on my Explorer. I know I can find an end wrench that will work, but won't be able to torque it. 'Course, when they say to torque something to over 200lbs I think you can just give it all you got and be okay...it's probably all academic around that level.
I could jsut kick myself over this...I rebuilt the thing a few months ago, and now it grinds between 3rd and 4th gears. Imagine how mad I was at myself when I realized I forgot to replace the fatigued synchronizer key springs on the 3/4 slider with the new ones:pat: The new ones easily have a 1/3 larger diameter to them than the old ones...I am so mad at myself!
Old Oct 25, 2003 | 02:45 PM
Shane's Avatar
Well considering that "special" dealer only socket will probably cost an arm leg and two kidneys and you'll probably only use it twice in your lifetime...
runnermedic
13
Sep 21, 2015 05:20 PM
--Oz--
Sep 6, 2015 01:06 AM
BigMike
Marlin Crawler
Sep 3, 2015 07:49 PM
mirabile4runner
Sep 3, 2015 07:15 AM
