squeak.....
Old Jan 7, 2003 | 04:48 AM
data's Avatar
Senior Member
squeak.....
I just had all my belts replaced at the dealership and now sometimes when I start the runner up it makes a squeak, but then it will go away. Anyone know the cause of this? Also it will happen when I turn my steering wheel sharply.
Old Jan 7, 2003 | 06:07 AM
Cebby's Avatar
Too tight/Too loose
Its one or the other. Did you look at the tension since it was done? They make something called "Beltease" that cures squealling belts, but that's hardly a fix...
Old Jan 9, 2003 | 01:21 PM
data's Avatar
Senior Member
I'm thinking it might just be the tension.
