self adjusting break question
Old Apr 7, 2003 | 03:30 AM
david in germany's Avatar
Unhappy self adjusting break question
Ok i just put some new shoes on the rear of the runner and they seem to get to tight after a day of driving (causing the truck to lurch to a stop) if i were to drive on snow and ice i would believe that that would cause me to loose control. what do you guys think i should do? I have loosened them up a bit and cleaned them again but I think they are going to tighten up again. I replace the old one because they were dragging and the shoe material had gotten so hot that they cracked.
David
Old Apr 7, 2003 | 10:00 AM
mtnfreak's Avatar
Dragging brakes is rarely the fault of the shoe or pad. You've got an internal problem. Perhaps someone with more experience has seen this before. FYI, most 'self-adjusting' brakes require you to use the parking brake frequently.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
thefishguy77
Jul 30, 2015 10:59 AM
Gevo
Jul 29, 2015 11:15 AM
calderp
Jul 27, 2015 09:58 AM
colasurdo
Jul 16, 2015 11:37 AM
