hard pedal
Old Apr 9, 2005 | 07:22 PM
hektikwon's Avatar
hard pedal
my 91 auto 4runner has a very hard gas pedal. is there a remedy i've done searches but i'm still not sure
Old Apr 9, 2005 | 07:27 PM
rugerm44's Avatar
cable
Check the cable for any kinks.You can take it loose at the pedal and at the carb or throttle body.Then have someone pull on one end and you on the othere.If its binding try lubing it.Make sure the throttle body isnt binding up also.If all else fails just put a new throttle cable on it.
Old Apr 9, 2005 | 08:21 PM
ChickenLover's Avatar
Your tranny kick down cable might be too tight or damaged. It's the one right next to the throttle cable on your throttle body. Unhook it and see if that's the problem.
PBRaddict#1
Aug 22, 2015 11:34 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
Backcountry411
Jul 24, 2015 08:06 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
