Bad news for the turd, mushy pedal
My brake pedal is starting to get kinda mushy so I looked at the MC. It looks like it has been leaking a little. I have heard that you can replace the seals in it and make it good as new without buying a new MC ($$$) I have also heard that a MC from a V6 truck will move more fluid and improve brake performance.
Can anyone point to a writeup for replacing the seals or offer any tips or suggestions?
Thanks in advance, Matt
I'm thinking i'll need to do some searching on POR for this. I'll soon have another big PITA repair under my belt. I'll also soon have torn everything on the truck apart and rebuilt, one piece at a time.
I relish these challenges.
Check out that Lucas Additive company! They sell it at most auto part stores. My buddy used it for his power steering and it worked. It's real cheap too, worth a try!
If indeed the master cylinder is leaking, replace it. ( with the proper M/C for the vehicle ) The master cylinder was designed to provide the proper coefficient of friction needed to stop the vehicle.That means it should be perfect as is.
Replacing seals is not always as good as it sounds. Its a little harder then it looks and the housing is aluminum. If your M/C is some what old, it very well may be pitted internally.
I recommend saving the $$$ and doing it right. After all brakes are some what important.
Good luck, kxpaul.
Good luck, kxpaul.
Good luck, kxpaul.
Good luck, kxpaul.
crammit442
7
Nov 29, 2017 12:30 PM
DiZ86
Dec 27, 2015 09:33 PM
nframe
3.4 Swaps
Aug 16, 2015 09:03 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
