Another Tune Up Question
Old Feb 13, 2003 | 09:42 PM
FUGGRWE's Avatar
When I bought my 4Runner last June, it had 80,100 miles on it. It now has 91,000. I checked the Carfax report and it says that it was registered as a "private lease vehicle". This leads me to believe that the previous owner probably didn't keep up with routine maintenance very well. Should I have a tune up done? If so, what should I have done besides having the spark plugs replaced?
Old Feb 13, 2003 | 10:01 PM
94 First Responder's Avatar
Every 25 i do gear oils,timing adjustment if needed, filters, and spark plug check. If you just got it and had the money, I would replace the timing belt and waterpump, plugs,wires,rotor, and drive belts, and antifreeze coolant flush, tranny fluid. Doing all of these or most will leave you good till about 125-30k. If you dont do the timing belt now have it done before you hit 110k i would say.
nonstop
7
Aug 11, 2015 09:26 AM
ChiefTetlow
Aug 10, 2015 04:19 AM
HollieJayyy
Aug 9, 2015 07:59 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
