96 4runner SAS TG frenched
just a quick lil writeup about my swap. 1996 4runner limited 3.4 auto. Front sas is done.. minitruck tcase is in. still need a new crossmember to get the 4wd hooked up. and do rear leaf suspension. i am doing the same suspension as in my old truck RUFS front, f150s rear. the only light thrown after the swap was the abs. the speedo still works because the limited 4runners have the sender in the transmission tailhousing. i was running old toytec coilovers before and i could barly keep the 4runner on the road. the sas handles great.
parts used
my original 1985 toyota axle, longs, trunnion elimator, 5.29s, spartan locker. highsteer
rear springs up front, 2 sets of 85ish springs,
ford shock towers
tacoma radiator as tg suggests
flat pitman arm
common toyota steering box
single tcase with 4.7 gear
tg adaptor
tg frenched shackle kit
rear is stock suspension on fj80 springs
parts used
ford shock towers
flat pitman arm
tg adaptor
Flying91
45
Apr 11, 2024 04:39 PM
BeMiceElf
Oct 10, 2015 09:40 PM
