Buying & Selling Advice - Feeler/Gauging Interest This general forum is for those seeking information about buying, model features/differences, pricing to sell, and related advice
questions?? for a futre owner
Old Jan 25, 2011 | 02:41 PM
YODA34's Avatar
first off this weekend i maybe trading my jeep for a yota. it is a 93 ext cab 4x4 5 speed with a 22re.. now my questions are what should i look for while im able to crawl all over it. and specifics please in where to look for frame rot things of that nature.
and the reason i didnt search is because i also have another question.
the truck has a mis fire and i know that it could be fauled out plugs bad wires a distributer or anythin i was just wondering if the 22re had anything that made it misfire that is a major problem.
thanks in advance yall.
Old Jan 25, 2011 | 03:26 PM
Swimmerboy2112's Avatar
Rust rust rust!! That is the killer! Check the frame and on the corners of the cab also the bed.
About the missfire, when i bought my 4Runner (22RE as well) it had a really bad missfire, I changed the plugs and wires and the miss went away.
Old Jan 25, 2011 | 03:32 PM
YODA34's Avatar
alrighty thanks boss. and the cab corners wont be a big deal i try to do body work for a living so i can do that. and i say try because im still fresh out of lincoln tech and i am an apprentice at the shop i work at. haha. thanks tho.
Old Jan 25, 2011 | 03:47 PM
camo31_10.50's Avatar
yea rust at the cab corners, bed sides at the bottom..anywhere on the frame.
where are you located? that contributes A LOT to the rust issue.
Old Jan 25, 2011 | 03:52 PM
YODA34's Avatar
unfortunatley i am in illinois haha. that causes alot of problems.
Old Jan 25, 2011 | 03:57 PM
ah i see, well...it might not be too bad rusted out! lol
Old Jan 25, 2011 | 04:43 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Rust on a 93? WTH are you guys talking about? I have seen rust on a 90's truck but that's what happens when you park and neglect a real truck under a tree and never wash the junk and leaves that cake up on it and it starts to corrode...
Not a "common" Toyota issue, other than a "common" moron owning the truck.
Rust is not common on those years of trucks... But it also depends on if it's been used in a salty climate and put away withOUT getting it off 1st.
The main thing you need to know is HOW to work on it. It has NOTHING in common with domestic junk and therefore requires new knowledge and understanding of how to maintain it.
2nd thing is its power. The 22RE while not powerful enough by Merican standards, will go almost for forever having had PROPER PREVENTATIVE MAINTENANCE.
And no, that does not mean run it till the T-chain breaks or the head gasket blows and you just slap another one on there without machining it 1st... Both popular options with dip-@#$% owners.
Finally, traction. All Toyota's came with open diffs. CONTRARY to popular belief you do not need 12" of lift and 44's to conquer most holes... As this will quickly add up to a dead 22RE and almost never ending spiral of money as you'll need gear$ and you'll want locker$... And a better clutch$ and cross member$... etc.
Get a locker and a nice well thought-out lift and you can still drive it.
Then you can pull up next to a 12" lift and 44" tire shod truck and ask him what his excuse is.
http://www.youtube.com/watch?v=iI9xHyngTyc
And, not only that, but you are trading WAY up by getting rid of that Jeep
Old Jan 25, 2011 | 04:48 PM
oh, and PS... Congrats, and, that's one of the most sought after trucks.
Old Jan 25, 2011 | 04:52 PM
if rust is not common on newer vehicles..........then why do the 3rd gen pickups have rust on them? as well as the 3rd gen 4runners (and 2nd gen 4runners) and 1st gen tacomas.
if if you wash your truck/4runner down real well, you can't ALWAYS get EVERY LITTLE BIT...and once rust starts, it'll go and go and go.
Old Jan 25, 2011 | 05:06 PM
Define, 3rd gen? 3rd gen as-in 4WD? Or sarting all the way back?
And 2nd, we don't need to rehash all this Tacoma frames built by Dana junk...
Also, nothing new about 85-88 beds rusting... With the non one piece bed sides... The only time I've seen 89-95 beds rust is when the exhaust pipe tip has broke off and fumes coat the back side of the bed starting corrosion...
Ever notice it's driver side, right behind the rear wheel well?
EDIT: and yeah, there is the chrome bumpers Toyota saw fit to chrome on one side
Yes, all (89-95) Toyota chrome is a ticking time bomb...
Which reminds me... OP, starting with the Tacoma, Taco's are made in America, and the frames were made by Dana Manufacturing (of Dana Axle fame)... Your truck, with a 22RE was made in Japan.
The Tacoma's (95 and ^) are Merican... And coincidentally it's around this time many say Toyota's quality started slipping... hmmm.... Coincidence? I think not
22repower's Avatar
You are lucky to find a NOT RUSTED pickup or older 4runner in Illinois, we seem to get more road salt on our roads than actual snow
Old Jan 25, 2011 | 05:08 PM
22repower's Avatar
89 to 95 are third gen pickups
also I have a 93 22re 4x4 that was built in the US
my truck is starting to also rust around the door corners, in thewheel wells, and inside of the bed
Old Jan 25, 2011 | 05:11 PM
tried, don't get technical, for all intensive purposes, this website refers to pickups as 1st gen...79-83, 2nd gen...84-88, 3rd gen...89-95 pickups, 1st gen 4runners...84-89, 2nd gen 4runners...90-95.
and no i don't notice anything about the exhaust rusting out the bedside, my buddies 94 pickup is rusted at the front fenders, bedsides all the way around at the bottom, bottom of the tail-gate, and both front and rear bumpers. it's NOT uncommon, in fact rust is probably more common of a problem than anything else with early (pre-95) Toyota's.
whats the first letter of your VIN number 22repower?
Old Jan 25, 2011 | 05:20 PM
22repower's Avatar
I can't remember at the moment but I know its different than my 94 from Japan
And my 94 did have the tailpipe rust, actually the only rust on it when I got it two years ago
Not so after three winters
Old Jan 25, 2011 | 05:26 PM
de'o's Avatar
I have a 94 ex cab and it has been amaizing although without all of the work done to it that i have done it would be pretty trashed by now. learn as much as you can about the suspension, its difficult to lift very high with the ifs suspension in the front. i went with an axle swap so i didnt care about that stuff but make sure everything in the front has been taken care of.
Old Jan 25, 2011 | 05:32 PM
22repower's Avatar
My truck had a ton of motor problems when I got it, but a $400 motor from the junkyard fixed that
I have drove it ever since I got my license, and haven't had anything but a starter go bad(except for the motor of course but got it cheap that way), and I definately wasn't exactly nice to it. These truck are just built well, I don't know of any other explanation
always have dreamed of having a first gen 4runner though lol
Old Jan 25, 2011 | 05:33 PM
22repower's Avatar
And for a jeep, for sure a good trade
mdev126
Oct 4, 2015 04:48 AM
shisha1999
Sep 21, 2015 08:22 PM
stock87yota
Jul 31, 2015 10:08 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 13, 2015 10:57 AM
