Looking to Sell some of my 22R/22RE LC Engineering Parts
Just Finishing up my Standalone ECU install .
I will be selling the following .....
LC engineering Polished plug loom holder
LC engineering Plug wire Set
LC Engineering Stage 2 mild Camshaft
LC Engineering 2wd Street Header Emissions holes welded up with new ceramic coating
OEM Toyota Supra Air Flow Meter
OEM Cold Start Injector
OEM Fuel Rail
OEM Distributor very low miles
OEM Coil Very low miles
OEM Ignition Module low miles
22re Valve Cover Polished on the top with black wrinkle on the sides ( machined for dual row timing chain and ARP studs)
Thanks for looking
OEM Fuel Rail
Thanks for looking
OEM Fuel Rail
Thanks for looking
OEM Fuel Rail
Thanks for looking
Updated.....
just finishing up my standalone ecu install .
Lc engineering polished plug loom holder sold
lc engineering plug wire set sold
lc engineering stage 2 mild camshaft
lc engineering 2wd street header emissions holes welded up with new ceramic coating
oem toyota supra air flow meter sold
oem cold start injector
oem fuel rail
oem distributor very low miles
oem coil very low miles
oem ignition module low miles
22re valve cover polished on the top with black wrinkle on the sides ( machined for dual row timing chain and arp studs)
thanks for looking
oem fuel rail
thanks for looking
