FJ Cruiser 2007 & on
All-Pro FJ Cruiser Slider Group Buy + NEW DOM Sliders!
Old Oct 4, 2012 | 08:40 AM
scuba's Avatar
It's that time again! All-Pro Off Road is offering a Group Buy on our #1 Selling FJ Cruiser Rock Sliders!
...well not really a group buy, just a smokin' sale!:smoker: BUT WITH AN EXTRA GROUP BUY BENEFIT - You'll get a $50 Gift Certificate* if we get 40 orders! Plus, 1 of the 40 will be randomly selected to get their All-Pro Rock Sliders for FREE! We have some of the standard HREW in stock for immediate delivery with or without plates. Please expect 3-4 weeks for delivery on the new DOM!
Pricing:
Over 15% OFF - Now Only $299/pr HREW, or $499/pr APEX DOM; PLUS add optional dimple die fill plates (see below pic) at 10% OFF - Now Only $89/st (HREW Only - DOM include plates).
These plates are welded in to the upper surface of the Rock Slider, creating a step-like surface to aid in entering and exiting the vehicle. Plates are CNC laser cut from 1/8" plate steel, and dimple-died to add rigidity and great looks.
Plus, here's more info:
ALL-PRO FJ CRUISER ROCK SLIDERS
Key Features:
•Ultimate Rocker Panel Protection!
•High Clearance
•Fully Gusseted
•Completely Bolt-On
•New DOM Version with Lifetime Warranty
•Made in the USA
Full Product Description
All-Pro Off Road's FJ Cruiser Rock Sliders are the best selling sliders on the market! Get the protection you need for your rocker panels without robbing valuable ground clearance. We designed these Rock Sliders with our signature "kick-out" design that is proven to help prevent damage to the vulnerable rear quarter panel by pushing your FJ away from the rocks. Unlike other sliders, our Rock Sliders angle up to provide the most ground clearance possible since there's nothing worse than getting hung up on low hanging armor!
All-Pro Rock Sliders not only look great, they are designed to stick out just enough to provide the needed protection and to allow for use as a step for roof rack access. No frame drilling is required since our Rock Sliders easily bolt on to the pre-threaded factory frame holes using the supplied grade 10.9 metric hardware. We ship these unpainted so you can finish them to your liking. We recommend using spray paint to allow for easy touch-ups when these sliders get put to good use!
Made in the USA using 1.75" steel tubing for the outer tube with 2" steel tubing for the inner tube, and fully welded and gusseted 2" square tubing for the legs. The beefy frame mounting plates are 3/8" thick plate steel (see photo at left) to withstand bending or tearing away under extreme abuse. Our Rock Guards will hold the full weight of the vehicle and a Hi-Lift jack can be used at any point along them. They are the most trail-tested product out there and have held up to the country's toughest rock crawling trails including the Hammers, the Rubicon and Moab.
Technical Data
Material:
Strong .120 Wall Steel Tubing
2" OD Inner Tube
1-¾" OD Slider Tube
2" Square Tube Legs
3/8" Mounting Plates
Hardware: Metric Grade 10.9
Weight: 79.0 lbs.
Dimensions: 60" Length
NEW APEX SERIES DOM Rock Sliders!
All-Pro has recently updated the Extreme Duty version of our FJ Cruiser Rock Sliders, as a new offering in our All-Pro Expedition (APEX) series. These sliders are made from beefy 1.75" x .125 wall DOM tubing with full length dimple die plates, along with fully gusseted legs mounted to 3/8" plates. DOM (Drawn Over Mandrel) tubing, which has a higher carbon content which results in a much higher tensile strength than HREW (Hot Roll Electrically Welded). And the cold-working DOM process results in superior dent and bend resistance. We've built DOM versions of most of our products for use on our own vehicles for years, and now we're making these available to the public. We're so confident in our Extreme Duty Rock Sliders that we're offering a LIFETIME WARRANTY against bent tubes!
Technical Data
Material:
Strong 1.75" x .125 Wall DOM Steel Tubing
2" Square Tube Legs
Weight: TBD
Dimensions: 60"L
Customer Testimonials
"I am running the All-Pro Rock Guards and have been very happy with their performance. Having the 'Kick-Out' provides additional protection to the side of my FJ and also gives me better access to the roof rack. I have put the Rock Guards to use in many tough situations and have found them to hold up well. My Rock Guards are painted with Rustoleum 'Hammered' paint which allows for easy touch-up."
Tomas Dawson
My Toyota FJ Cruiser | My Toyota FJ Cruiser, Modifications, Expeditions, Mods, Equipment, gear, Photos and more
"I put my order in for DOM, and you shocked the cr@p out of me by how fast they showed up at my house .... the end result IS THE BOMB. Awesome fabrication. Period. I have some good stuff on another rig, but, seriously, these are scary perfect. Experience here with All-Pro? 110% or more satisfaction (more actually)."
-Matt (SuperV3K), Phoenix, AZ
Frequently Asked Questions
Q:How far do the All-Pro FJ Rock Sliders "stick out"?
A: FJ Rock Sliders stick out approximately 4" from the front door seam. At the rear "kick-out", it extends to about 7" from the rear door seam.
Q:How should I prep these and what paint should I use?
A: Clean with paint thinner, prime, then paint with Rustoleum, Krylon, or the equivalent paint in the color of your choice.
Q:Is powder coat available?
A: Powder coat is available for local pick-up only, for an additional $120. However, since powdercoating is harder to touch-up, we recommend using spray paint instead if you plan on using them where they will get strached.
Click here to go directly to this page on our website. Please note, when ordering online use coupon code FJGB-15
Don't settle for less, get the best!
Group Buy pricing good through November 1, 2012
*$50 Gift Certificate will be valid from 1/1/13 - 12/31/13 and is only good on future orders of All-Pro brand products.
1.
2.
3....
We will add your name to the list once we receive your order. THANKS!
Old Oct 5, 2012 | 08:24 AM
scuba's Avatar
In stock and ready to ship today!!
Old Oct 8, 2012 | 12:32 PM
scuba's Avatar
To the top
Old Oct 10, 2012 | 02:17 PM
scuba's Avatar
Bump.
Old Oct 11, 2012 | 02:09 PM
scuba's Avatar
Moar!
Old Oct 25, 2012 | 08:37 AM
scuba's Avatar
Only a few more days folks!
Jun 1, 2021 01:51 PM
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
_Nicco_
Sep 21, 2015 03:06 PM
Regency
Sep 4, 2015 01:32 PM
coryc85
Jul 6, 2015 04:07 AM
