93-98 T100s All T100 trucks
Gear ratio A05A 1994 T100 DX
Old Apr 7, 2014 | 07:44 PM
Killer B's Avatar
The axle code on a 94 T100 that I recently picked up is A05A, I counted rotations of my driveshaft/wheel and it is 4.71- the 94s seem to be the only year that had this ratio from what I have read.
Has anyone else confirmed. their 94 with same gear code?
Old Apr 16, 2014 | 08:32 AM
BamZipPow's Avatar
According to www.car-part.com, here's what they show fer 1994 rear axle ratios:
4 cyl, 3.62 ratio
4 cyl, 3.77 ratio
6 cyl, 4x2, 1 ton, ABS, 4.455 ratio
6 cyl, 4x2, 1 ton, ABS, 4.70 ratio
6 cyl, 4x2, 1 ton, w/o ABS; 4.455 ratio
6 cyl, 4x2, 1 ton, w/o ABS; 4.70 ratio
6 cyl, 4x2, 1/2 ton, ABS, 4.08 ratio (MT)
6 cyl, 4x2, 1/2 ton, ABS, 4.27 ratio (AT)
6 cyl, 4x2, 1/2 ton, w/o ABS; 4.08 ratio (MT)
6 cyl, 4x2, 1/2 ton, w/o ABS; 4.27 ratio (AT)
6 cyl, 4x4, ABS, 4.455 ratio (MT)
6 cyl, 4x4, ABS, 4.70 ratio
6 cyl, 4x4, ABS, 4.90 ratio (AT)
6 cyl, 4x4, w/o ABS; 4.455 ratio (MT)
6 cyl, 4x4, w/o ABS; 4.70 ratio
6 cyl, 4x4, w/o ABS; 4.90 ratio (AT)
1993 had these ratios...
(6 cyl), 4x2, 1 ton, ABS, 4.455 ratio
(6 cyl), 4x2, 1 ton, ABS, 4.70 ratio
(6 cyl), 4x2, 1 ton, w/o ABS; 4.455 ratio
(6 cyl), 4x2, 1 ton, w/o ABS; 4.70 ratio
(6 cyl), 4x2, 1/2 ton, ABS, 4.08 ratio (MT)
(6 cyl), 4x2, 1/2 ton, ABS, 4.27 ratio (AT)
(6 cyl), 4x2, 1/2 ton, w/o ABS; 4.08 ratio (MT)
(6 cyl), 4x2, 1/2 ton, w/o ABS; 4.27 ratio (AT)
(6 cyl), 4x4, ABS, 4.455 ratio (MT)
(6 cyl), 4x4, ABS, 4.70 ratio
(6 cyl), 4x4, ABS, 4.90 ratio (AT)
(6 cyl), 4x4, w/o ABS; 4.455 ratio (MT)
(6 cyl), 4x4, w/o ABS; 4.70 ratio
(6 cyl), 4x4, w/o ABS; 4.90 ratio (AT)
Old May 8, 2014 | 07:44 PM
Killer B's Avatar
Ok, so here.is what I got, I was wrong- A05A is 4.90 and A04A is 4.70
Here is a picture of the ring gear out of a 1994 T100 with A04A, it has the 4.7 ratio stamped on it
jashoeuh
Nov 18, 2024 08:08 AM
polo451
13
Nov 20, 2016 07:49 PM
Scotto6591
Sep 1, 2015 03:24 PM
coffey50
Jul 28, 2015 10:55 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
