93-98 T100s All T100 trucks
Front diff oil seal leak?
Old Sep 18, 2010 | 03:23 PM
MTNiner's Avatar
Hello,
I'm hoping for some input on the difficulty of replacing the front diff outer oil seals. Possibly replace anything else needed while I'm in there (other seals, gaskets, etc...).
I have a 97 T100, 4x4, 3.4L with high mileage (190K). I noticed the other day when I was changing the oil that there is oil leaking from the right side front diff where the side gear shaft enters the diff housing. I am assuming that its the outer oil seal that is the problem. I would rather do the work myself but I wasn't sure how difficult this repair would be or how much a shop would charge. I have tools, although would need to get some of the special tools like the oil seal puller, etc... I am determined, have know-how, and I prefer to do the work myself so I can learn rather than paying someone else to do it.
I have done google searches and forum searches and haven't found much on this topic, sorry if I missed something and am re-posting.
Let me know if any more info is needed to help with input, I can also post some pics it they help too.
Thanks again,
Shane
Old Sep 18, 2010 | 04:05 PM
toyomoto's Avatar
hey dude,
i can only think your talking about the pinion seal if the leak is coming out of the diff housing. thats a real easy job, only thing that is CRITICAL is your torque on the pinion nut when you put everything back together. MUST be at torque spec which is usually 180lb/ft+. not sure exactly what it is for your truck. make sure you got a proper torque wrench but other than that, ya way easy job.
Colington
Mar 8, 2020 09:51 AM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
andrewtexas123
Jul 14, 2015 04:29 AM
HRDC0R19
Jul 5, 2015 06:43 PM
