93-98 T100s All T100 trucks
door handles suck
Old Nov 19, 2018 | 03:00 PM
Bret71's Avatar
door handles suck
1997 4x4, just bought, door handle already broke (passenger side), I have a 95 2wd, same issues, anyone know a good fix for this aside from the plastic clips?
Old Nov 23, 2018 | 06:56 PM
Wayne Garcia's Avatar
Same
I’ve had the same issues with my 96. Both handles broke, I replaced them and the passenger side broke again, Mind you I used eBay parts but the driver side is still good for now. I’m waiting to find metal handles
Old May 7, 2019 | 04:20 PM
fidoplank10's Avatar
Part of the plastic molded handle has a little dog-tab that engages the metal latch and linkage. Once you pull the inside door panel off, you can loosen the handle assembly from the door, but don't have to fully remove the linkage arms. I drilled a hole in the remainder of the handle and screwed in a stainless bolt, about 3/4".
I used stainless to go small diameter bolt, with good resistance to bending.
Pale blue is where the dog/pawl broke. Left the linkage rod in place.
Damn Dog
Stainless bolt: take care with drilling pilot hole. I was lucky and just glanced the axis rod.
Old Jun 21, 2019 | 02:36 PM
SaltyMethods's Avatar
Great solution. I've had to replace a few of these handles. They are weak.
Blownchevelle68
91
Mar 18, 2019 03:53 AM
4x4spaz
Jul 16, 2018 03:36 PM
lbhsbz
Apr 2, 2018 01:13 AM
Turboz
Oct 9, 2017 01:33 PM
