93-98 T100s All T100 trucks
95 t100 solid axle swap.
Old Aug 20, 2022 | 12:05 PM
T100Toph's Avatar
Hey yall, I bought a 95 t100 sr5 4x4 that I thought was stock but turns out it was a monster. On my road to return to stock I discovered the rear axle was actually out of a Ford ranger (stamped k6). The truck drove fine in 2wd but would seize in 4x4 and the drive angle was incorrect even though previous owner fabricated the mounts upside down to try to correct it.
I have since got a proper toyota t100 axle with matching axle code put in there but it brought up an interesting question
Has anyone successfully solid axle swapped a t100 with one of these Ford ranger k6 axles/diff? the width and gearing is right or at least close (may have to regear) but obviously all new mounting brackets would need to be welded. I assume the cost would still be over a couple grand even already having the axle for disc swap/suspension upgrades.
just trying to see if this is even a viable concept before I decide whether to sell the axle or not.
Old Aug 20, 2022 | 12:19 PM
millball's Avatar
Proper t-100 axle??? Pretty sure T-100's are independent front suspension.
Old Aug 20, 2022 | 01:24 PM
T100Toph's Avatar
yes thats why I am asking if the axle removed from the rear would work for a front sas swap.
Old Aug 20, 2022 | 01:33 PM
millball's Avatar
Huh??? No rear axle from any make or model would work.
Rear axles have no provision for steering.
Old Aug 20, 2022 | 02:15 PM
T100Toph's Avatar
ahhhhh ok nevermind, im an idiot and need to do more research lmfao thank you for the replies. Sounds like im selling that axle after all
17dodgebros
Jan 18, 2018 10:03 PM
swinkjoe26
Jun 19, 2014 05:06 PM
yotaman97
Jan 15, 2014 04:57 PM
wolv_aaron
Aug 22, 2010 05:10 PM
