General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Running light problem
Old Jun 2, 2016 | 07:16 PM
Irishman03's Avatar
I have a 93 4Runner an a few days ago the fuse popped. I changed out all the old lights to new, spent many hrs tracking down the wires to see if there was a bare wire exposed. Here's the catcher.. It all works while I'm parked but 5 mins on the road it pops again! I don't get it any ideas out there before I go nuts!?
Old Jun 2, 2016 | 08:14 PM
akwheeler's Avatar
5 Year Member
intermittent shorts to ground can be a royal pain, what I have done in the past was to put a slightly larger fuse in the original and put the rated fuse farther along the circuit with slightly smaller ones on each branch of the circuit. you'll have to go to the wiring diagram to pick where each should go. at least put a smaller fuse at each light. if the main blows your short is between that and the next fuse. if one of the smaller branch fuses blows your short is on that branch and the remaining branches will still work. good luck
Old Jun 2, 2016 | 11:43 PM
wyoming9's Avatar
Now you are talking tail lights here .
Try swapping a good tail light relay in see if that cures your problem .
Might be a problem in either the coil or the contacts in the relay once it gets hot it draws to much and opens the circuit protection.
Old Jun 3, 2016 | 04:42 AM
Irishman03's Avatar
My break lights work just fine. Its the 2 front corner lights, the dashboard, license plate lights or also know as the parking lights.
Old Jun 3, 2016 | 08:59 AM
akwheeler's Avatar
5 Year Member
if it gets to where it's repeatable in the driveway you could remove all of the loads and disconnect sections of the harness checking for a short to ground, but with an intermittent you will be better off with the divide and conquer method with progressively smaller fuses strategically placed on each branch of the circuit. running lights/dash lights/ license plate lights will lead you through a lot of harness. best to figure out which leg/branch to be looking at.
tumor21
9
Jan 12, 2018 07:56 PM
87runnerhawaii
Jun 8, 2016 12:02 PM
Poppie51
Mar 25, 2016 02:16 AM
Yont283
Mar 9, 2016 04:33 AM
Vernsyota
Mar 7, 2016 04:41 PM
