General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
ODB1 error 21 can't be cleared
Old May 1, 2023 | 12:45 PM
g00se's Avatar
Hi,
I'm running an imported 2001 Japanese Hiace Super Custom 2.4l petrol (2RZ-E engine). This doesn't have a OBD2 port - only the Toyota ODB1 / DCL1 port. The engine management light is NOT on but I connected the TE1 and E1 to get any flash codes. I got '21' - which I believe is oxygen sensor. I've done some reading and I came across something that said the computer will store a 21 error without putting the engine management light on - but will light it is it receives a second 21 on a later drive.
I know the battery was replaced a month ago - so I assume the error was picked up since then. I thought it's reset it and see if it reoccurs. I've tried both disconnecting the EFI fuse for 30+ secs and also the vehicle's battery - but the error reoccurs immediately. I can't get rid of 21 flashing up on the dash.
Could this mean the oxygen sensor is kaput or it's connection is effectively cut? But wouldn't this eventually bring up the engine light on the dash?
Any thoughts welcome
sollyburton
Dec 25, 2012 02:21 AM
xDUKEx
Jan 31, 2010 03:16 PM
Axe 'Em
May 6, 2009 09:55 AM
j4eric
Sep 7, 2008 06:26 AM
Joec500
Jun 25, 2003 10:13 AM
